Gun help? seems to be wasting a lot of material !
  • Gun help? seems to be wasting a lot of material !
    Ok guys heres my delima, I got a powder coating gun from harbor freight. I have been using it the past couple of days an im starting to notice that the gun seems to waste a LOT of powder? can someone tell me what im doing wrong? Im not sure why its doing this but its making me mad. Can anyone help ?
    Re: Gun help? seems to be wasting a lot of material !
    Wasting a lot as in......? Like is it shooting to much powder? If so, just lower the PSI some. Or is just a lot of it falling to the ground? Maybe you don't have a good ground or your just spraying to much in the first place, which could relate back to what I said up there^.
      I have one of those guns myself, and I've noticed it does like to waste if you're not careful. Shoot, my trigger's been stuck open for about a month now, so I have to use the screw at the bottom of the handle to regulate the flow/pressure. I've noticed it doesn't take a whole lot of pressure, so try turning that screw way down. Also, don't load the cup too full, I've found 1/3 full or less works well.
        wow i feel stupid, i didnt even think about that screw. its like having a paint gun, and that is the material screw how much comes out !! I have to get a new air compressor but i will try that ASAP !!
          kcrails,
          Without a powder cup on, screw the air adjuster on the gun clear in and put about 60 or 70 psi to the gun. I'm pretty sure the adjuster is downstream of the trigger... you need some psi against the trigger to push it back out.
          Adjust the screw out to set the pressure to the cup.
          Did that make sense?
            Originally posted by Popeye
            kcrails,
            Can you put that in English ?
            Thanks,
            JHF
              kcrails, in addition to what popeye said, you might be able to make the trigger work freely again by taking it apart, cleaning it, and lubing it with a little silicone grease. I did that to mine after the trigger began to stick and it made it work like new again.
              Steve Dold
              http://stevedold.com
                JHF,
                Which part? Or all of it
                  JHF,
                  all of it, was that just explaining how to adjust the out of powder to the gun? or was that explaining how to fix his sticky trigger ?
                    Mainly for the sticking trigger..
                      Ok im having problems with WAY TO MUCH material coming out !!
                        First thing I'd do is take the diffuser tip of the gun and pitch it.
                        It just takes some time and practice... play around with different psi settings and different amounts of powder in the cup.
                        I wish there was a hard and fast answer but there isn't. I know it can be a little frustrating at first but you'll find the sweet spot with the gun.
                        It's the nature of the beast
                          Popeye,
                          Not too worried about fixing the trigger, it actually kind of helps me having it that way. When the trigger did work, it would glob a bunch out when I'd hit the trigger, didn't seem to matter where I set the pressure. I should probably upgrade to a pro-model gun anyway.
                          And the diffuser came off after my second botched job. Never had many issues after that.
                          JHFGSX9D,
                          How full is the gun cup? After the feed pressure, that's where I'd look. I generally keep mine below 1/3 full.
                            Remove the little plastic tip on the end of the gun ? what will that do ?
                            Thanks,
                            JHF
                              It should spray better
