Cost per Square Foot
  • Cost per Square Foot
    Hello Everybody:
    I've been lurking in the threads for the last two years. With everybody?s help I have a powder coating business I've started.
    My major customer is a blacksmith that wants the cheapest flat black job I can provide. But now I been approached by a corporation building some new equipment. I know when you deal with a corporation the prices double if not triple over Joe Blow that wants a set of valve covers coated but with the money is coming out of his pocket. With my black smith I base the cost per oven load.
    The parts they want coated consists of Hoffman electrical panels, some flat plates 30" x 46" x 12 gauge, 5" x 36" x 1", etc.
    Does anybody have experience with corporations or a price per square foot I should charge?
    Thanks
    Gary
    Re: Cost per Square Foot
    I have struggled with this also, but you should be in the $30-$35/sq.ft range. This would include doing the prep work. If you are just wiping clean and coating you would reduce accordingly. Hope this helps.
      Estimated Volume would help to figure this out!
      Pre-treat required,racking cost per part, rack time per part, powder cost, mil thickness required, square foot per piece, oven cycle time, packaging required labor, etc.
      The company I managed ranged from $0.65 to $2.50 per square foot depending on the complexity of the part and the volume of those parts.
      Hope this helps a little.
        Thanks for your replys.
        These parts are new, so I'm just going to wipe them down and spray them. As far as packaging, I work for this company and I'll be delivering them when I go to work. I was thinking around $5 to $7 per square foot.
        Thanks Again
        Gary
