i am going to be applying the Physco Lime topcoat with a Super Chrome under coat to my friends dirtbike frame.As well as the Physco Yellow with gold flake with Super chrome under coat to another friends dirtbike frame.
I recall reading on the forumns awhile back about the process,but cant seem to find it.
If i recall correctly.I need to preheat the frame then allow to cool to around 160 then apply my coat of super chrome.Flash bake for roughly 10 minutes then apply the candy coat.Also when do I need to add the flake,can I just mix it in the physco yellow or is it going to be a 3 step process?
Can some one varify this and or go into a little more detail for me,oven temps and cook times for each coat.Thank you in advance.Eric
