Any direction?
  • Any direction?
    I am in the final stages of my oven building, and was wanting to ask for some fan motor direction. What hp motor and what size pulley for the secondary shaft to change the cfm of the fan blade? AC motor is what i'm going to use. Any help would be greatly appreciated.
    Dee
    Re: Any direction?
    How big is the oven? How much air do you want to move? And I'm guessing you're going to run a jack shaft to drive the blade?
      Re: Any direction?
      The oven is going to be 4'wide 6'deep 7'tall.And yes I want to run a seperate shaft for the fan blade to reduce heat on the motor
        Re: Any direction?
        Send me an email and I send a small PDF file with the formulas.
