Color match for cosmoline (cosmolene)
  • Color match for cosmoline (cosmolene)
    Is there anything that replicates the color of cosmoline ?
    I have someone that does restorations and wants to be able to have the same coloring as cosmoline, without the mess.
    Ideas?
    Re: Color match for cosmoline (cosmolene)
    Dark brass candy is close.
    SS
      Can you add something to get the candy topcoat a true flat finish ??
        Gloss killer.
        http://www.caswellplating.com/powder/additives.html
        SS
          Ideas?
          What is cosmoline?
            Cosmolene is a protectant against rust used on automotive parts, machine shop tooling and equipment that will be stored for a unknown or indefinite period of time. Fresh it is almost like a grease. As it ages and dries out, it gets gummy and then hard. It has to be cleaned off with a solvent before the item coated can be used.
            SS
              Is there anything closer in a RAL color or something to keep from doing a 2 stage process?..
                They put cosmoline on jap scrap when they ship it to the US because of the ocean salt. On a quiet day you can hear a Toyota rust....
                mach
                TSA Custom Metal Finishes
                Live fast, Die sideways
                  The dark brass is a candy top coat. Why would you have two stages?
                    I was thinking that you meant putting it on with a chrome basecoat...
                    It would be nice to get something that is ready to shoot without having to mix the gloss killer, it would help in the consistency.
                      I haven't seen anything else with a low or no gloss.
                      SS
