Brake Caliper ?
  • Brake Caliper ?
    When you coat brake calipers, do you completely disassemble them or do you leave the 2 halves bolted together? Can the o-rings between the caliper halves handle the cure temp heat? I have the pistons, seals and piston o-rings removed. These are Porsche ATE calipers.
    Ed
    Re: Brake Caliper ?
    I would disassemble completely, that's what I always do. Be sure to mask off the mating surfaces though.
    mach
    TSA Custom Metal Finishes
    Live fast, Die sideways
      Re: Brake Caliper ?
      mach
      Thanks.
      Ed
