I was noticing the sandblasting cabinet thats advertised here says its supposed to have at least 12 cfm at 40-80psi. Where could I possibly get a compressor to run this to strip old powder coating and paint? Would I have to run at least a 5hp? any help appreciated.
which compressor for sandblasting?
Re: which compressor for sandblasting?
12 CFM would probably require something around a 3-5 HP unit. However, you could use a smaller compressor if you used a smaller nozle. It's also possible to use smaller compressor if you don't mind waiting for the compressor to catch up. However, if the compressor runs constantly it will heat up and put more water in the air. Most sandblasters won't even touch powder coating. You need a good aircraft stripper to remove powder coating.
Joe
Originally posted by jbotti1You need a good aircraft stripper to remove powder coating.
Joe
btw be careful with this stripper it is nasty stuff. read and follow the safety instructions on the can. best of luck bro.when in doubt polish it out/ why replace it when you can refinish it
Originally posted by jbotti112 CFM would probably require something around a 3-5 HP unit. However, you could use a smaller compressor if you used a smaller nozle. It's also possible to use smaller compressor if you don't mind waiting for the compressor to catch up. However, if the compressor runs constantly it will heat up and put more water in the air. Most sandblasters won't even touch powder coating. You need a good aircraft stripper to remove powder coating.
Joe
Originally posted by pickleboyi agree on this sandblasting will surely remove powder but it is slow. the aircraft stripper(not the low odor version) comes in a blue 1 gallon can with an airplane on it. available at most auto parts/auto paint suppliers. it is a little costly but worth it. coat the part fairly heavy and then cover with a large garbage bag(this will keep it from evaporating to fast). let this set for about 1/2 hr. come back then a check to see if all the powder is bubbled and lifted. if so use a plastic scraper to clean the bulk of it off in the same garbage bag then throw that bag in the trash. rinse the part very well. and then go to the sand blast to prep for new powder.
