I bought the phosphate solution from caswell and I just wanted to know the best way to use it. After diluting with distilled water, and soaking the part in the phosphate, is it necessary to rinse off the part or just dry it? Also, when I did some parts when I pulled them out the the solution and was getting ready to dry them, some faint yellowish color appeared on the parts. Is this flash rust or is it the phosphate coating? I read that phosphates will attack any surface rust left on the surface. Is this true?
Thanks, Ross
Thanks, Ross
