holley carb
  • holley carb
    hi everybody
    my friend ask me to powdercoat his holley carburator
    i m not sure about the way to do it
    once again i m askink for your s precious infos
    thank you
    Re: holley carb
    ouch. It would have to be completely torn down, as there are rubber seals inside that won't hold up to the heat. All mating surfaces have to be masked, as well as threaded holes and openings. It can be done, but it's a project.
    good luck!
    mach
    TSA Custom Metal Finishes
    Live fast, Die sideways
      Re: holley carb
      when mach says torn down that includes the butterfly plates on the bottom due to holley having teflon seals for the shafts. it can be done as mach said but what a pain
        Re: holley carb
        the carb is completely dismantle
        i powdercoat only the casing of the float bowl and the corps
          Re: holley carb
          i did the job
          came out ok after degassing at 450 for 1 hour
          the only thing bugging me and it s happened for the second time
          seem i got trouble to make the powder stick in the deep place of the part
          the part have been sandblasted, clean whit brake cleaner , the ground look ok but the powder don t go on the deepest part
          i m working whit a hobby gun from youre competitor ( i know i know)
          any trick ,
            Re: holley carb
            if you shoot the part warm between 120-150 degrees it will help pull the powder into the tight spots.
              Re: holley carb
              i try to make touch up right after it came out of the oven
              the part was at 200 f and the powder melt in a second making difficult to coat the missing points
              is it possible the material carb are made of is a poor conductor for ground
              or the competitor gun don t worth ....... like you says in english
                Re: holley carb
                If I remember correctly the problem is caused by something called the Faraday effect. This happens in smaller recesses where the electrical fields in the surfaces close to each other interfere with one another.
                SS
                  Re: holley carb
                  that is it for sure. hlk you might try taking the deflector off then heat the part and shoot the recess area with no deflector.
                    Re: holley carb
                    Hey Hulk easy on that hobby gun dude there not bad. Works for me. LOL
                    Thanks Pickleboy I've been doing the hot part thing, but I will remember the removing the deflector thing.
                    You know I just started playing with this to do my kids quad stuff. But learned a lot from all you guys on this site. My buddies ask me where I learned so much about power coating I tell them from the Caswell chat site.
                    The $100.00 gun did this hulk SWEET
                      Re: holley carb
                      great job mikekozura
                      interesting youre tip pickleboy about the deflector,but what will be the effect,and how fare i gonna have to shoot, no danger to coat whit to much powder
                        Re: holley carb
                        From reading earlier posts before I got my gun, I put the deflector discs in the tool box and never have used them. May not work for you but could be worth a try.
                        SS
                          Re: holley carb
                          without the deflector more powder will come straight out of the tube. this will cause more to go down the hole where you want it to. just dust it lightly and you should be fine.
                            Re: holley carb
                            Thanks Hulk. I'm sure the carb came out great. Hey how do you but them little faces and sh@t in the post I can't find it anywhere.
                            I'm going to stick with the deflector on mostly flat pieces. And remove it for sh@t with a lot of nooks and cranies to hold the melted butter. Wait thats for english muffins. But you know what i think that'll work, thanks SS and Pickleboy.
                              Re: holley carb
                              If you go to remove the disc during a shoot be sure to turn it off and discharge first or you know what'll happen.
                              SS
