Anyone know where I could get some color chip sample panels that I could powder coat for sample products? Thanks...
Color chip sample plates?
Re: Color chip sample plates?
Go to Lowes or Home Depot and pick up a piece of 26ga or 16 ga sheet metal, when you run a color shoot a sample at the same time.. Keep and eye on the chip as it will cure faster then your part, unless your part is of same size and metal...
Jim S...Jim Shuster
www.backyardpowdercoating.com Sold.....
www.chrissys68mustang.com Hobbie
www.photogserver.net Web Hosting.
I buy a piece of pipe and cut in into inch pieces.Jeff B.
Instructions for riding a Warrior: 1) sit on bike, 2) start bike and idle till warm, 3) pull in clutch and put in gear, 4) release clutch and rip on the throttle, 5) {VERY IMPORTANT!!} HOLD THE F*** ON!!!, 6) Enjoy!! Side effects may include whiplash, wrinkle free skin, and an evil smile resembling the "Joker".
Originally posted by hvac36Go to Lowes or Home Depot and pick up a piece of 26ga or 16 ga sheet metal, when you run a color shoot a sample at the same time.. Keep and eye on the chip as it will cure faster then your part, unless your part is of same size and metal...
Jim S...
Originally posted by callmej75Well I got alot of samples to make out and mail out to different people needing color samples for their products. I used some plates already pre-cut into maybe 3"x4" plates that I used in florida but don't remember where I got them.
Go to the same places and pick up 4X4 electrical cover plates... Nice size and cheap.. Think .50 each... Sand blast to remove galvanizing. Then powder..
Jim S...Jim Shuster
Jim S...
I went to a local Sheet Metal shop...purchased 500 3X4 samples with 1/8" hole in one end for hanging for $50. They are galvanized also, but that is fine because they can lay in the box and be somewhat protected until I am ready to use them.
Call a shop and tell them exactly what you are going to use them for and you are looking for an inexpensive solution.Last edited by OKTRX450R; 02-24-2006, 09:42 AM.
http://www.q-panel.com/?CatID=1
callmej75, Is this what you are looking for?
Jason
www.autocyclepc.com
Jason
www.autocyclepc.com
