I've been powder coating my engine parts with a poylester coating and wiped the finish with a little laquer thinner and had a dulling reaction to the finish.I tried carb cleaner with the same results.Dot 3 brake fluid, ant-freeze had no effect on the finish.I thought this type of powder would be ok for this purpose.I didn't clear coat.Am I doing something wrong or is this normal.I wanted to do a carb.Thanks for your opinons.coach
Powder coating problem
Re: Powder coating problem
Or another way you could check for full curing is the MEK rub. Take a rag and dip a small part in MEK and rub it back and forth applying light pressure maybe 6-10 strokes. No powder wiping off means you have cured well.
If it was me...I would try to cook it for maybe 5-8 minutes more. If that don't cure it then do a bunch of sample panels and mark them at different curing times. Better yet, get a infrared thermometer and test out a part by putting it in the oven and see how long it takes it to heat up to the temp at what your powder says to bake at. Thats when you start the time specified for the powder. When the part reaches that temp is when the powder starts to cure.
are you sure its a case of under-cure? I've done pieces that had plenty of cure time- they aren't affected by Gasoline, MEK, paint prep cleaner, ect. everything except for Aircraft remover (of course) and lacquer thinner- after all isn't powder coating just a different style of paint? maybe I'm wrong.Save the trees- burn Rubber!
