air compressor
  • air compressor
    would an air compressor used for air brushing work with a powder gun? The specs I have on it are....30psi. 1/8hp. 1700rpm. 1/8 outlet 115v. 60hz. .75amp. 90w.
    Re: air compressor
    It will probably work as well as the 12V compressor sold to operate the hobby guns but you won't be happy in the long run. The gun cleanup recommends 100 psi. There is always a need to blow parts off or dirt and dust out of,from under and around your oven. A small compressor with a 20 or 30 gallon tank would be more appropriate on a budget system.
    SS
      Re: air compressor
      good point....wasn't looking at other uses, but you're right, I do need one for other things in the shop too.
        Re: air compressor
        I just bought a compressor like that for my setup. I already have a big compressor for my tools, but this was an oil less and would make my PC booth self contained. I hope it works.
