Improve the flow of the hobby gun...
  • Improve the flow of the hobby gun...
    Has anyone attempt to improve the flow of the hobby gun? I have problems with "hard to reach" areas such as complexed wheels and similar. Always tend to get thicker on some areas than other and its visible on the end result. I have played with the different nozzles but still not the flow i would like. So, anyone done any further tricks to the gun?
    WEIRD Performance & Coatings
    Sweden
    Re: Improve the flow of the hobby gun...
    I made 4 1/8 holes to the small plastic tip
    it works better for deep areas
      I've had the best luck without a tip. Spray in a lot of tight corners without a problem.
        I have a attachment a guy made and sold them on ebay. It works real well. I will see if I have a pic of it.
          Thanks, would be nice to see some other solutions on the tip...
          Sweden
            I read in a diffrent thread about removing the tip, i tried it and it worked great. I did notice a diffrence in the amount of material flowing and the tighter pattern. I had to move farther away from the part and move the gun a bit more quickly around the part due to the increase amount of material.
            But i think i will try the holes in the tip too, wont hurt to try.
            If it jams; Force it. And if it breaks it needed replacing anyway.
            I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
              Add me to the list of removing the tip for tight areas.
                great result for the holley carb whithout the tips
                shooting the powder at 36 inch from the piece at 7 psi
                cover deep part on 2 strokes
                  36" from the part? I would guess you mean 3-6 inches....
                    The only time I use the tips anymore is for large area parts.
                    mach
                    TSA Custom Metal Finishes
                    Live fast, Die sideways
                      mtumbleson
                      i really wrote 36 inches but make it between 24 and 36 inches depend of the parts
                      i shoot in a continuous flow,whit a small circle paterna lot of powder combing out of the gun make sure you can catch the overflow
                      i never shoot from 3 o 6 inch it seem like disturbing the powder on the pieces
                      shooting whiteout the tip is great especially on pulley
