I had an engine built last year for my truck, and they painted it a Ford Blue color using spray paint cans. It has been sitting unstarted since then and has started to flash rust, can I still powdercoat the engine block if I mask off all holes and openings? You would think an engine filled with oil could handle up to 450deg. but just wondering what you guys think. Thanks.
Engine Block question
Re: Engine Block question
I dunno man... I consider gaskets, any silicone. as for the oil.. i think there would be burn-off (contamination of powder), plus i'd have to think out-gassing would be impossable with a pan full of oil. the paint would have to go too.
Personally? i wouldn't do it unless it was a bare block. just my 2 centsIf it jams; Force it. And if it breaks it needed replacing anyway.
I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
