First post but ive been looking around quite a bit.
I have been thinking about starting my own home powdercoating setup for a bit now.
I have a few questions i guess mostly just some conformation on what i want to do, and if it will give me good results.
First, i will be using a conventional electric oven.
*1* is there a good way to hook up a vent hose to vent the fumes away from the oven to the outdoors?
I will be building my own spray booth using some examples from here. Ill use a fan and filter method.
*2* How do i make sure i have a good ground in my spray box?
For sandblasting i have not made up my mind. I guess i could build my own box and such but this is the part i have been having the most trouble with.
What is a good setup for sandblasting. I will mostly be doing small items, but possibly as large as a wheels? Also, what sandblaster should i get such as the gun and then what material?
Overall i need mostly sandblasting help.
Thanks,
Jash
Thanks,
Jash
