Hello all! I'm new to the forums and the whole powder coating hobby. I hope to learn alot while i'm here. Hopefully i'll be able to help in the future after I gain some experience.
Now on to the questions.
1. The Black Satin (BHK) coating is an "Air Drying" coating, does it require anything else to fully cure it? or just apply and it's good?
2. The picture of Black Satin looks like it's a liquid, how do I apply the Black Satin coating? (ie; powder gun, paint gun, paint brush, etc).
3. Which coatings can be used inside of exhaust parts (ie; inside ehaust manifold/headers, inside of turbo housings, etc.). I was thinking that i would like to use Black Satin (or what ever is better for this idea) to coat the exhaust runners, the exhaust manifold, the inside and outside of the turbo housing, and finally the inside of the ehaust down-pipe that goes from the turbo to the catalytic converter. Will Black Satin withstand this abuse?
4. I visited the Tech Line website to learn more about the CBC1 POWERKOTE. They have a product called CBX POWERKOTE which is "Designed for Performance engines running; Nitrous oxide, Supercharged or Turbocharged. For all other applications use CBC2". The CBC1 says it's for "High performance engines", but says nothing about turbos/nitrous/superchargers. Anyone have an idea about how I could get some CBX?
5. The Tech Line Internal Engine coatings DFL-1 POWERKOTE and CBC1 POWERKOTE are "water-based", what equipment is used to apply these two coatings?
Thanks ahead of time for the help!!!
Jimmy
Jimmy
