About grounding foil board
  • About grounding foil board
    I am thinking about making a spray booth like your's LeeParsons. Using the foil board and 2x4's. My question is how did you ground all the walls and did it help with the (I think this is right the extra electrons) keeping or pulling them away from the part getting pc.Also thinking of hooking a shop vac to bottom corner of booth to pull in air, will this work.
