Are you satisfied with your compressor?????
  • Are you satisfied with your compressor?????
    A question for anyone using a blast cabinet or other tools that require lots of air.What size is your cabinet & how much air does it draw from the compressor?What size compressor are you using to run the cabinet?....horse power,tank size, cfm @ 40, & 90 lbs.?I'm in the market for both a cabinet & compressor.Some input & recomendations would be great.
    Re: Are you satisfied with your compressor??
    i built my cabinet 6/3/3 i use a 20 cfm air nozel in it.
    i have 120 gal air tank / 2-60 gal water heater tanks i have an air compresour off a service truck 27 cfm @ 145 lb.
    so more than enouf air for my needs.
      I have an 18x32 blast cabinet, 4hp 26 gallon compressor. could probably use a little bigger, but it gets me by. Runs an impact wrench just fine, too.
      mach
      TSA Custom Metal Finishes
      Live fast, Die sideways
        Machone.....what is the cfm rating on your compressor? What brand?
          I have a 28X46X28 blast cabinet. My comperssor is a 60 gallon with an upgraded 18 cfm pump. The original pump was a 10 cfm. The compressor was a Home Depot special that I got on sale the entire setup cost about $550. This setup has no problem keeping up with the demands we put on it. The upgraded pump works great and was very easy to install and the company I bought it from was great with their customer service.
