rust remover??
  • rust remover??
    I'm new to this forum and have successfully powdercoated a few small parts. PC is 1000 times better then painting! I've got some parts that I've sandblasted but can't get small amounts of rust out that is in certain spots because of the angles involved. Will PC adhere to any rust inhibitors/coatings?
    Thanks,
    dmend
    Re: rust remover??
    Thanks,
    dmend
    I'm still a noob, so I may not be 100% on this. I dont think it will adhere to the inhibitors/coatings. If you need to remove the rust that's hard to get to, try something like Naval Jelly or some other rust remover like that. It is basically a jellied acid, which would make it pretty easy to apply to that hard to reach area without coating the rest of your piece with acid.
    And remember, you can quickly find out if it will stick by using a piece of scrap and coat half of it with your rust inhibitor, then PC it. Nothing worse than having to clean a good part that had a small ammount of PC not stick because of something like the rust inhibitor.
    59 Volvo PV544
    87 Shelby CSX #239
    88 Shelby CSXT #707
    88 Shelby CSXT #745
    87 Mustang LX
    92 Mustang GT
    www.jamperformance.com
      Re: rust remover??
      navel jelly will work, so will 50/50 mix of muratic(hydrochloric acid sold as concrete/pool cleaner) and water. If you want it to be faster, put in a piece of SS sheet or lead, hook the neg side of a battery to it, and the positive side to the part. Keep a close eye on it, it may start removing base metal. Acid can be neutralized with baking soda afterwards.
        Re: rust remover??
        dmend,
        Try these: http://antique-engines.com/electrol.asp http://www.stovebolt.com/techtips/ru..._derusting.htm
        John
          Re: rust remover??
          I tried the Naval Jelly. I must have what is considered very thick rust. After many coats, even an overnight coat, there is rust underneath where I can scrape at it. One thing I don't like about naval jelly is the combination of water and metal... seems counter intuitive.....I did end up with a nice surface coat of rust on most of the piece. Electrolysis, not willing to try that just yet.
          dmend
            Re: rust remover??
            At a trade show I saw a product called Evapo-Rust. It looked to work pretty well at the demo. I haven't used any yet but thought it might be worth mentioning.
            Evapo-Rust Super Safe Rust Remover is easy to use, environmentally safe product that removes rust in minutes, without scrubbing.
            www.spitfirecustoms.com
