Low temp powders?
  • Low temp powders?
    Can any one tell me where to get small amounts like 1-5 lb of low temp. I am trying to find powders that cure around or under 300f. Sherwin Williams has custom made powder for plastics but it only comes in 50lb. I am going to try and coat the plastic with a material to make it conductive. Or can someone tell me where to find uv cure powder and if it would be better. Thanks for any help.
    Re: Low temp powders?
    if you coat the plastic with a conductive paint it will crack at cure temps
    I have been able to coat plastic at 50Kv
    problem is plastic melts at cure temps
      I was going to coat the plastic with copper powder do you think that will crack? If it is calling for 10 [email protected] I guess it will not work to put it at lower temp for longer time.
