The closer I get to purchasing your kit, the more I realize that an oven won't suit all my needs. Most, but not all of the stuff I will be doing will easliy fit into an oven. However, there will be large pieces (Vespa frames) that will not.
How effective are these heating lamps? Do you have to enclose them to aviod heat loss? What kind of curing coverage to you get (or, how large an area will the heat lamp cure at one time.)?
Thanks
Thanks
