2nd coat is messed up?!?!?!
  • 2nd coat is messed up?!?!?!
    I did a frame for a guy and i decided i would spray a 2nd coat on after it had cooled because i had missed a few spots. So i pre-heated the frame and then coated and it came out looking like a satin finish that is grainy. What did i do wrong?
    Re: 2nd coat is messed up?!?!?!
    more info will be help full
    a couple things can cause that.
    what color
    temps (pre heat and cure)
    time in the oven etc.
    it happend to me a couple times with some solid tone colors and if the second coat is applied at over 150.
      Exactly- the metal is hot enough to melt the powder but not to let it flow out. Also if the second coat isn't thick enough (due to not enough power, poor lighting ect..) it will have a grainy finish.
      Save the trees- burn Rubber!
