I have just finished a large run of Translucent Orange and alot of them ran. Sagged with drips and such. Other pieces didn't. Seems like the smaller pieces sagged, the Brake levers, foot pegs etc. The Rotors, and triple tree came out fine. The oven was 400, but I heated up with the parts inside. I am using my large oven, and have to hang each part individually, so can;t preheat oven. I did preheat the pieces, in the small oven, to aid in the application. Could it have been to long a bake causing the runs on the smaller parts? Instructions are 10 min @400. I went 10 min after oven reached 400, takes 45 min to get to 400.
Translucient sagging
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
"If it ain't broke, modify somethin till it is"Tags: None
Re: Translucient sagging
Too much powder or too much heat. Hang smaller pieces toward the bottom or near the level of your TC. I've even set/hung shielding panels for small parts. Depending on where your TC is located, the small parts could have reached temp long before the rest of the oven. But, I'm thinking too much powder.
I think it's just this powder and the color darkness that I am trying to acheave. I re-did the pegs, baked them at 380 fro 15 instead of 400 for 10. But, this time I hung the pegs flat, how they will be mounted on the bike. Alot better, but still more buildup on the bottom edges. Sagged. Not oil or anything, they were extensively cleaned, and prebaked, preheated. I did the pegs in 2 shots this time too, I sprayed a lighter coat, looked smooth, but was not the color I should get, wasn't even at teh sample piece I recieved from the manufacture. SO, andother spray, and finished baking, look ok now.Dan Pesonen
Personal motto:
Dan Pesonen
Personal motto:
I had the exact same problem spraying Tiger trans brass for some block-off plated on my SE. I had to spray three coats to even get close to the sample. First try it all sagged. I sprayed it over chrome, too.
I have had the same thing happin.Its just too much powder.The stuff runs like water i hate doing orange and purple trans.I have found that if you let the part cool down to wear the trans.lays on top with out melting you can lay it on thinner and more even.Iam trying to go with the dormat colors they look better and are easy to do
It's Tropical Orange. Not from Caswell. Prismatic powders
And there is more pics on my pic gallery.
http://banditpowdercoat.com/Powdergallery/nfpicturepro/Dan Pesonen
Personal motto:
powder hates right angles!! you could knock down those edges to avoid that look. it looks bad!SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
[email protected]
sigpic
I've had the same thing happen with me. I put clear over Xtreme Chrome with it preheated and I had drips on it as well. I figure that I put on to much clear while they were hot. Sanded them and hit it with car polishing compound and it came out perfect.Who says you can't teach an ole dog new tricks?
i've had the same issue with candies before too.SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
[email protected]
sigpic
