2 Color & Chip Repair Confushion??
  • 2 Color & Chip Repair Confushion??
    if i can spray 1 color, bake, pull it out and spray another color and bake then why couldnt i spray a chipped area of a single color and re-bake?
    Re: 2 Color & Chip Repair Confushion??
    While you may fill the chipped area, you'll have overspray all around (it would look like you did not apply enough powder to a part). Your options are to try and sand (feather) the edges of the chipped area and recoat the whole part, strip and start over, or try this for hook mark repair, may work for a chip. (check post #4) http://forum.eastwoodco.com/showthre...ght=hook+marks
      you can spray over the chipped area & re cure. as said sand the edges of the defect to blend/smooth as best as u can & re-spray. if you're doing that though it's a good idea to recoat the whole part for uniformity reasons.
      SouthWest Powderworx
      Tyler Nutter
      5054803934
      www.swpowder.com
      myspace/swpowder
      [email protected]
      sigpic
