Translucent (Lollipop Red) Problem
  • Translucent (Lollipop Red) Problem
    This was my first time spraying a translucent over chrome.. Had some runs on several pieces. Seemed like maybe to much powder
    Re: Translucent (Lollipop Red) Problem
    Yes, too much powder will cause you to get the runs.
    Did you spray the part hot or cold?
      I allways spray Lolly's Hot. Best way to ensure even coverage IMO
      Dan Pesonen
      Forest Grove, BC Canada
      Personal motto:
        yup!!!! that'll happen. you have to get the hang of the candies to get good results.
        SouthWest Powderworx
        Tyler Nutter
        5054803934
        www.swpowder.com
        myspace/swpowder
        [email protected]
        sigpic
          well i ran it up to 400, pulled it out then sprayed it, but i think i out on more than i should because i had to shake the gun alot to get it to flow...my bad
            I've used green and blue, but did it cold. came out pretty good. Get the powder to look fuzzy, but not furry. It worked for me.
