for those of you that use professional guns
  • for those of you that use professional guns
    What brand do you use & are you happy with it's performance? I use a Wagner Prima Airfluid with a C4 gun.
    SouthWest Powderworx
    Tyler Nutter
    5054803934
    www.swpowder.com
    myspace/swpowder
    [email protected]
    sigpic
    Re: for those of you that use professional guns
    i have a nordson versa spray II and a wagner EPG 2007 and can't be any happier.
    well maybe with a surecoat.
      i use a GEMA PG1 and i like it . it does very well in those hard to reach areas
      http://www.peintureenpoudrepb.com
      http://www.polissagepb.com
      http://www.powdercoatpb.com
      baz
        Eurotech
        http://www.powdercoatingsupply.com/M...em%20400D.html
          why do you say this? we're moving to a new shop in a month or so, and we decided a few months ago to purchase the nordson sure coat once we're settled in. seemed like a quality and versatile gun that fits our needs.
          Len
          Figure Finishing
          www.FigureEngineering.com
          866-900-4949
            sure coats, and 1 older versa spray. Work well
              Looking into one of the Eurotec 400's like Harleydad. Just fed up with the inconsistent powder delivery. Small parts is fine, but covering a uniform coating on a 4 x8 sheet of steel, plasma cut artwork on it, Just cant get consistent
              Dan Pesonen
              Forest Grove, BC Canada
              Personal motto:
                Do yourself a favor and get a fluidized hopper also. If you like the cup guns thats also an option.
                  Fluidized Hopper is better How is the color changes, Time wise? I often need to change colors in 10 Min or less, Like when doing chrome/clear, or multi color jobs, half baking, then shooting next color. Thats why I was thinking the Box Feed, Because all my powders are either 55Lb boxes or 5L pails.
                  Dan Pesonen
                  Personal motto:
                    Use the hopper for colors you'll have on for some time. Better fluidization. I have some jobs that are 400, 500 parts. Box feed is fine if you change all the time and I can chance colors in less than 10 min. I don't like to use the 55 lb boxes just because of the weight. It seems to get compacted even though the part it sits on only vibrates when the trigger is pulled. Seems worse this time of year (humidity).
                      Ya, I do some parts runs of 300+ as well, but then other times I am doing 5 colors of just a couple pieces in each color. How is it for low powder quantities? Whats the min amount of powder you need in the hopper to spray? Alot of times it's only 1 or 1/2 Lb I need of a color. Just basically thinking about the most versatility I guess.
                      Dan Pesonen
                      Personal motto:
                        I use tall plastic containers for smaller runs, the same containers I store my Golden Grahams & Raisin Bram in! they are ~ 5" diameter & 15" tall. they will hold ~ 5 lbs. of powder. for the system I have you can use the 55lb. boxes or this smaller scheme.
                        Tyler Nutter
                        5054803934
                        www.swpowder.com
                        myspace/swpowder
                        [email protected]
                        sigpic
