2nd Coat Question
  • 2nd Coat Question
    ive noticed that first coats go on very smooth, but if i missed a small spot, and decide to spray a 2nd coat its not as smooth as the first. first is almost like glass and the 2nd is a little rougher. is this normall with powder on top of powder or is there a trickto nicer 2nd coats?
    Re: 2nd Coat Question
    Are you trying to just touch up the light spot or do you cover the whole part? Are you sanding between coats and are you spraying them hot (hot flock) or cold?
    Do you have an adjustable kv gun?
      50kv gun, respraying the whole piece, warm, like about 160deg, not sanding between spraying
        that happens with glossy powders. 2nd coat glossy's can be tough. if a 2nd is needed w/ a glossy powder let it cool, sand & apply over the whole thing.
        SouthWest Powderworx
        Tyler Nutter
        5054803934
        www.swpowder.com
        myspace/swpowder
        [email protected]
        sigpic
          After the sanding I'd blow it off with clean,dry air.
            sand with what grit?
              220 should work for ya.
                It sounds like you could be having a transfer efficiency problem. The 2nd coat might be a little thin. A thin coat will give you a rougher, tight orange peel effect. Do you have a gage to check your cured powder thickness?
                www.spitfirecustoms.com
                  i'm assuming we're all not completely inept @ this whole thing.
                  Tyler Nutter
                  5054803934
                  www.swpowder.com
                  myspace/swpowder
                  [email protected]
                  sigpic
