Black Chrome Question
  • Black Chrome Question
    When Applying this powder do you need to polish the aluminum first?
    Can they be done raw (no polish)
    Or over chrome powder coat
    I am wanting to get my rims done like this: http://forum.caswellplating.com/phot.../size/big/cat/
    Re: Black Chrome Question
    Always polish to the desired shine and finish BEFORE plating or finishing. A thin metal plate even the black chrome will only show any imperfections...
    Strip
    Clean
    POLISH
    then plate or treat...
    Ed
      Strip
      Clean
      POLISH
      Ed
      Sorry I wasn't clear, I was asking about the black chrome powder coat.
      If i was to media blast the aluminum and not polish it will it come out looking good still?
        If that black chrome is not a translucent/candy color you should be fine. Obviously you don't want too knarly of a blast profile.
          It is listed under the "candy" section of casewell's.
          But I think it is a translucent black color.
            In that case, if you don't want to polish then all nice shiney, a base coat of x-treme chrome or the like should work for ya. If you decide to polish first, be sure you remove all the polishing compound before pc'ing.
              Would putting the x-treme chrome under the "black Chrome" look the same as polishing the aluminum first?
                as Ed said the better the substrate looks, the better the finish will look.
                SouthWest Powderworx
                Tyler Nutter
                5054803934
                www.swpowder.com
                myspace/swpowder
                [email protected]
                sigpic
                  Thanks for all your help guys.
                  I went down and talked to the powder coat shop. And they recommend using a chrome base and using there blue chrome. Which does have a slight green hue to it, but is most accurate to actual black chrome..He quoted me about $80-90 a wheel, does that sound right for a two stage color.
                    sorry i ment black chrome
                      black chrome from caswell is a candy ( tint)
                      i got nice results over polished parts and over real chrome plating.
                      over extreme chrome and near chrome bases i did not like the results at all
                      and over bare metal was plain ugly
                      http://www.peintureenpoudrepb.com
                      http://www.polissagepb.com
                      http://www.powdercoatpb.com
                      baz
                        Same here, I used Tiger Drylacs black chrome and did not care for the green hue it has over extreme and bare metal. Yes, that seems to be decent price for the wheels, depending on how tough they are to strip.
                          The powder that the coater is using is Tiger Dylac, and it does have a slight green hue to it. BUT, if you look at really black chrome plating it has a slight green hue to it.
                          The wheels will have this color to them at the end...
                          http://hdwheels.com/images/40-60_Spo...0and%20Hub.jpg
