Any ideas on what causes this? (pockmarks in the powder coat)
  • Any ideas on what causes this? (pockmarks in the powder coat)
    The grill originally had several coats of latex paint on it. It was sandblasted to bare metal, out gassed for one hour at 400 degrees, dipped into a five gallon can of thinner, hung to dry, blown off and brushed off of any remaining sand, powder coated with a Red Line Alpha gun at 75,000 volts, put in an oven and heated to 350 degrees as indicated on the powder and held there for 10 minutes as indicated on the powder.
    Parts of it came out perfect and parts of it have these pockmarks in it. Why?
    Glenn R. Lever
    Rochester, New York 14617-2012
    My Cars http://www.leverfamilysite.com/vehicles.htm
    Control arm Info http://www.leverfamilysite.com/GM_A_body.htm
    Join us July 6-8, 2007 for the 5th Annual Northern Chevelle Gathering, Niagara Falls, NY!!!
    Re: Any ideas on what causes this? (pockmarks in the powder coat)
    overbuild .
    too much powder on some areas
      So the area with the pockmarks has to much powder on it?
      Glenn R. Lever
        yes, it looks like it ,
        it might have happend when coating the fins
        at 75kv it might be too much kv for reaching inside the fins so that means you'll drop more powder trying to reach the insides and therefor overbuild on the outside or around the area you where trying to reach.
          Thanks. I will try that.
          Glenn R. Lever
            autoshopowner,
            You say you dumped it in a 5 gal can of thinner. If so the thinner may have contaminated it. Try using Acetone or Alcohol to clean.
            John
              I'm with jrow, loose the thinner. Nothing petroleum based.
                I have never had any problems with the thinner leaving a residue. What would you use?
                Glenn R. Lever
                  Most any pre-paint cleaner should be o.k. I use Acetone and some like to use rubbing alcohol.
                    I'm going with powder build up. If you were to sand out the pocks and reapply a light coat and fire it, I believe it would fix it. How many people do this?
