Pricing help
  • Pricing help
    I really pretty much do automotive parts and dont really have a good idea of how to price simple stuff. What would you suggest for this plate. It would 55 of them, 6"x11", blasted and ready to coat, low gloss black.
    Unorthodox Creations Powdercoating
    Re: Pricing help
    $25-$30 each but for that many probably give 'em a deal @ $20 each.
    SouthWest Powderworx
    Tyler Nutter
    5054803934
    www.swpowder.com
    myspace/swpowder
    [email protected]
    sigpic
      Re: Pricing help
      Really that much? Maybe I wasnt clear but it is just the plate you see there. The base its on is plastic.
        Re: Pricing help
        Can you batch them?? bake a bunch at one time in your oven? I charge by the hr when I do work like that. $45.hr shop rate. If they are allready cleaned, blasted and ready to go, then should be 1- 1.5 hrs to spray, and then bake time. I charge customers the labour time at shop rate, then my oven time is a different rate. $25/hr and usually charge 1 hr bake fee. Takes an hr to heat oven to cure temp.
        My most common work is pieces 3-4 times the size of that panel, but 200-300 at a time. Hr rate works great. I tried the by piece billing but was hard to keep accurate count, and if there was any issues with their product, It was not accounted for with the by piece method.
        Dan Pesonen
        Forest Grove, BC Canada
        Personal motto:
          Re: Pricing help
          oh, the stand is plastic ha. well then I would definitely charge less. probably $10-$15 each but given the amount of pieces I would give a batch rate. We have an hourly rate of $55/hr. I would base the overall price on that.
          Tyler Nutter
          5054803934
          www.swpowder.com
          myspace/swpowder
          [email protected]
          sigpic
            Re: Pricing help
            My oven is big enough I can do them all in 2 batches, probably about 2 hrs time including oven warm up. I was think $3 a piece, or about $150. Is that way low?
              Re: Pricing help
              pretty awesome deal for your customer but hey its good experience and maybe word of mouth will increase your customers...
                Re: Pricing help
                I can fit all of them in one batch and it would still be closer to $10.00 ea. Just because they say blasted and ready to coat is not necessarily true. Just wait until you see some to quote a price.
                  Re: Pricing help
                  i would do them for 10 each
                  remember if some of them get damage
                  you'll have to strip them and re coat ,thats extra time and powder.
                    Re: Pricing help
                    Wow, maybe I AM to cheap LOL. I think $10ea is to much, $5 not bad, especially if they are all blasted. But, look them over first before guaranteeing that price. Also, if there is a "screw up" and one has to be stripped, if it's a screwup you did, it should be on your dime, but if its because of the prep the guy did, then his dime. But I find it best to explain that first, to a customer rather than shocking him with the billl LOL
                    Dan Pesonen
                    Personal motto:
                      Re: Pricing help
                      $10 each? LOL... You guys would go hungry around here.
                        Re: Pricing help
                        WHats worse, price low, make less, but get return buisness, or price high, once.
                        Dan Pesonen
                        Personal motto:
                          Re: Pricing help
                          That's what I meant by going hungry Dan. Trying to get $10 each for that plate would drive the buyer to someone else. (You'd end up with no food on the table.)
                          You can't look at national prices and base yours on the same parameters. You need to look at the local market. In some markets, you might get $20-$25 each but that's not going to happen around here. This site is good for getting a range because there's folks from all over but your local conditions may not be the same. Heck; if you're in mid-town Manhattan, you might get $50 each but your overhead will be different too.
                            Re: Pricing help
                            Ohh, LMAO, My bad HAHAHA
                            Dan Pesonen
                            Personal motto:
