Problem with Clear Coat on Al. Wheel
  • Problem with Clear Coat on Al. Wheel
    I clear coated (Columbia Clear)a polished al. wheel and it has pin holes.
    How can I fix this? Can it just be sanded and re-coated or does it all have to come off?
    Thanks
    Fred Mc
    Re: Problem with Clear Coat on Al. Wheel
    the pin holes are from the wheel out gassing on you. strip it, re-polish, outgas the wheel then re shoot the clear. you just created quite a headache for yourself bro! if it's for a client that is
    SouthWest Powderworx
    Tyler Nutter
    5054803934
    www.swpowder.com
    myspace/swpowder
    [email protected]
    sigpic
      Its not a customer wheel, its my own.
      Is there a chemical stripper I can use?
      Thanks
      Fred Mc.
        yes there are quite a few out there. the cheap ones are aircraft stripper & gasket remover both available @ any auto parts store. the good stuff, IMO, is from solventkleen. it's there dizzolve 1012. caswell sells it also I think under a different name, maybe I'm wrong though.
        Tyler Nutter
        5054803934
        www.swpowder.com
        myspace/swpowder
        [email protected]
        sigpic
          Well, I was told to reheat it to 385 for 15 minutes, let it cool for 5, then re shoot. That just made it worse.
          So off I went to the autoparts store for some spray-on aircraft stripper. I sprayed it on, it foams up and I left it for 15 minutes or so. Then it just power washed off real easy. No rubbing, scrubbing, or even swearing.
          Now to outgas and re shoot.
          I was also told to shoot it hot. Is that right? The first wheel I did turned out nice and I shot it cold.
          Thanks
          Fred Mc.
            who ever is giving you that information is wrong!! don't listen to them bro. yes now that it is bare outgas it & let it cool, then re-shoot & cure.
            Tyler Nutter
            5054803934
            www.swpowder.com
            myspace/swpowder
            [email protected]
            sigpic
