Techline Black Satin failure
  • Techline Black Satin failure
    I installed Techline Black Satin on a set of exhaust pipes, and two turbo charger housings. The one turbo charger housing started peeling and surface rust was showing - the coating had obviously fallen off in small spots and the metal beneath was rusting. The exhaust pipe on that turbo was also Techline coated and it too started peeling/rusting. I did an exhaust manifold on another vehicle and it too started flaking, as well as that turbo housing.
    My prep is exactly what the directions state. I blast the items with glass bead to clean them, then I wash them off with acetone and blast them again with aluminum oxide. I then spray the material using a HPLV gun and let it air dry for 20 - 30 mins and then put it in an oven at 750 - 800 degrees to cure for an hour. What is the problem? I just coated my next turbo housing and its not on the car yet - I fear having to do it all over again.
    Thanks,
    Jon
    Re: Techline Black Satin failure
    Hmm, I better go back to one of my customers and see how his Turbo down pipe is holding up. We tried the Shiny cerakrome on it first, that jiut peeled off due to to much heat. So, I got some Satin black for him(had to eat the cost of redo)
    Dan Pesonen
    Forest Grove, BC Canada
    Personal motto:
      Please let me know - I would hate to put my new gigantor turbo on and have it look stupid
        you must start counting the hour once the part has reach the cure temp (750)
        aluminum oxide is recomended to be 80-120 grit
        if the aluminum oxide is old and broken it will leave dust on the surface so you'll have to clean the part with acetone or MEK before coating .
        you can also test if the part is really cured is by lightly touching the part ( while in the oven) with a screwdriver , if it leaves a mark it's not cure yet , it should be rock solid .
        these are the only things i can think of right now.
          The finish seems absolutely solid I can scratch at it here on my desk. This turbo hasnt been installed yet and thus has not been tested. But, I'd think that even if I did leave it in for only 45 mins of "up to temp", it surely got cured on the car?
            Thanks,
            Jon
            Dont use glass beads.
            Mike
            Mike
            MJM Powder Coating
              Mike
              Wrong - I use glass beads to clean the parts, then I aluminum oxide blast it. Please read the whole post.
                I did.........just an idea
                Mike
                Mike
                MJM Powder Coating
                  I have to agree on the glass, you just close the pores with glass, and regardless of using alu oxide after you may still have hammered in the unwanted particles in the material. Never the less, still seems like a double workload to me....
                  WEIRD Performance & Coatings
                  Sweden
