Newbie ? on primer
  • Newbie ? on primer
    Hello all, I have been pcing for about 6 months now. Nothing real serious but now some other customers want some pcing done.
    Normally I dont use primer at all. I simply sand and or blast, degrease, dry in the oven then spray powder and bake. I have been getting pretty decent results but when I spoke to a local pc shop they say I should prime everything.
    Searched the forum and didnt see a whole lot on primer. What are your thoughts and procedures?
    Re: Newbie ? on primer
    I use primer only for steel parts ( zinc primer)
    to gave it an extra corrosion resistance.
    I don't see why use it on anything else .
      glossy dark colors really show the tiniest defects. priming the base or using a different color base coat GREATLY reduces those defects from occurring. I use primers or base coats on most everything, not always though.
      SouthWest Powderworx
      Tyler Nutter
      5054803934
      www.swpowder.com
      myspace/swpowder
      [email protected]
      sigpic
        Tyler, what are you using for Primer/basecoat? Been getting alot of .....Black requests lately, and know exactly about the surface defect thing LOL. But I aint smoothing a new set of checkerplate running boards, or box rail caps, clients would think I was insane for labor charges
        Dan Pesonen
        Forest Grove, BC Canada
        Personal motto:
          I use zinc rich primer sometimes but mainly I use satin black or gloss white as base coats. I cure them around 1/2 to 3/4, & depending on the piece shoot the main coat around 130 deg or let it cool, sand it & then apply the main coat. it helps reduce orange peel on glossy colors as well. I always apply my sub-sequent coats with my Wagner with the voltage @ 30 & full current.
          Tyler Nutter
          5054803934
          www.swpowder.com
          myspace/swpowder
          [email protected]
          sigpic
