Does anybody have any tips on getting a good coat with candies or other 2nd coats. I am using a standard and selectable voltage gun rfom caswell and extreme chrome base. I am having problems getting the powder to attract on the 2nd coats. I have tried new grounds and have had only little better sucess. Please let me know if you all have some helpful info. My 1st coats always go on perfect. Thanks...Brian
2nd Coats Candy
Re: 2nd Coats Candy
hot flocking is a lousy way to shoot!SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
[email protected]
sigpic
Re: 2nd Coats Candy
I try not to hot flock anything. when I shoot 2nd, or subsequent coats I always ensure a clean ground & turn the voltage down to 30 & full current on my gun. you really have to pay close attention to how much you are spraying because with candies they tend to build up on the edges & run if they are not sprayed uniformly.SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
[email protected]
sigpic
Re: 2nd Coats Candy
Thanks for the advice. I got the idea from reading other posts on here from much more experienced coaters than myself. The first time I tried it, the part came out so much better than previous attempts without heat. It just seems to be a much easier way to do it. Is there any structural disadvantage to doing it hot?
Re: 2nd Coats Candy
no there isn't.SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
[email protected]
sigpic
Re: 2nd Coats Candy
Thanks for some tips. I shot some stuff today and it is just not getting good adhesion. I have tried extreme chrome, near chrome and a silver metallic. I am shooting a freshly coated part so it isn't dirty, but I still have problems. Part might be the candy, but I am sure you all are having success. I don't really know what else to do. Should you clean the part before puttin on the 2nd coat?
Nutty, could it be the fact that i don't have a real expensive gun, I have ground off clean points for contact.
I had real bad results with the near chrome and extreme was better, but this batch of extreme i bought is just as bad as the near was.
Re: 2nd Coats Candy
we have an expensive gun and it doesn't really help with candy over a base. i've tried a lot of techniques for shooting over a base aside from hot flocking it (some of our parts are too thin and therefore cool too quickly to hot flock), and the results are always frustrating/disappointing. i only plan to shoot over polished metal from now on. it looks *much* better anyway.
Re: 2nd Coats Candy
yup. it sure does.SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
[email protected]
sigpic
Re: 2nd Coats Candy
I have had good results with my Itw Gema gun on Candy coats and even third coats. The other day I did at set of valve covers with a silver base, candy purple 2nd coat then a supper high gloss clear for the third coat. The Parts came out great. I put the clear coat on cause I sanded and polished down the top fins.
Re: 2nd Coats Candy
same here , i also use itw gema (old style PG1) and i am getting good results with 2 , 3 , and even 4 coats (i rarely do 4 coats but have done it a couple of times )
but i also agree with what others have said ,candys are much nicer over polishing
Re: 2nd Coats Candy
I have always found that shooting 2nd coats with a forced charge gun is very difficult. If I have to do it I make sure that the part is as clean as I can possibly make it (with solvent such as denatured alcohol) and turn the charge down. Touching the part with your hands or leaving ANYTHING on the part can screw up the way it accepts the charge. You have to spray areas ONLY long enough to achieve coverage, but not so long as to get back ionization. If you notice spots of back ionization it's probably contamination either on the part or in the first coat. What has always worked great for me is using a tribo gun (from Intech, but they're no longer in business, I don't think). I've gotten great coverage for up to three or four coats. This is just from my own experience, and I don't often spray with HP powders so I don't have any experience with the "candies" that you're talking about.
