What causes powder coat to chip easily
  • What causes powder coat to chip easily
    I am a bit concerned about this because I have done some parts and come out flawless but they have a tendency to chip real easy. Im wondering if this is due to under baking of over baking or some other reason. What is it that im doing wrong? And what should I do to prevent this?
    Thanks
    Re: What causes powder coat to chip easily
    under cure &/or improper surface prep.
    a hammer will do it too!
    SouthWest Powderworx
    Tyler Nutter
    5054803934
    www.swpowder.com
    myspace/swpowder
    [email protected]
    sigpic
      yes most likely under cure.what are your steps for cure time?
        I dont really have any specific steps, but im all open ears. I pretty much wait till the part is pretty close to the indicated cure time and leave it in until the time indicated on the can
          You need to get yourself an IR Temp Gun. If the cure instructions say 10 min @ 400, it's when the part reaches 400 degrees, then start the clock. You need to open the oven door a bit to check the part temp. Don't try reading the temp thru the glass.
            Ok will give it a try. Thanks
