Chrome Powder
  • Chrome Powder
    After I sprayed on the chrome powder and cured it, it came out of the oven really shiny. They I sprayed on the clear and put it back in the oven, this time it is not near as shiny. What did I do wrong?
    You did it correctly, that is the way it suppose to look like. I did try Hot Coats new line of reflective chrome. It holds it's shine even with a top clear coat. You might want to look into that.
    360 Air Intakez
    http://www.360airintakez.com
      Ok I ordered a can of reflective chrome and a can of clear. I'll try it and see which one I like best . Thanks.
        Re: Chrome Powder
        How many microns do you think you powder film is ? Clear coat powder coat has a tendensy to get yellow or not so bright at high film thickness.
        You may try again, putting a little bit less on your subject, it might help.
        Did you know that it is possible to use every gram of powder if you recycle when coating, and vapors are almost none !
        In a wet paint approx. 80-90 % evaporates into the air. Causing stress on the enviroment !
        1 kg. of powder can cover approx. 10-12 m3
        1 litre. of wet paint covers approx. 2-3 m3
          ok thanks I'll try that. I havent done any more but plan on doing a few items on my bike this week.
            Let me know how it turns out
              Re: Chrome Powder
              Where can you get "Hot Coats" Chrome powder coat you mentioned in the forum? [email protected]
                Re: Chrome Powder
                Also - why do you need clear?
                  Re: Chrome Powder
                  U get hot-coat products from that other place!
                  SouthWest Powderworx
                  Tyler Nutter
                  5054803934
                  www.swpowder.com
                  myspace/swpowder
                  [email protected]
                  sigpic
