Newbie with Questions:
  • Newbie with Questions:
    Got everything setup and have been reading a lot of the postings, but have this one question? I purchased Caswells Liquiguard PC for aluminum and not exactly sure how or if I need to even use it. I'm PC over T-6061 aluminum which I have milled and not sure what to do next. I've read about washing it, pre gasing, blasting, not blasting, not needing to pre-gas because it's not cast aluminum. wiping it down with acitone, etc, etc.
    So exactly what do I need to do to prep the aluminum??-
    sign me confused.
    ben
    Re: Newbie with Questions:
    wipe it down with denatured alcohol, make sure it is dry which it will dry very quickly & shoot it.
    SouthWest Powderworx
    Tyler Nutter
    5054803934
    www.swpowder.com
    myspace/swpowder
    [email protected]
    sigpic
      Nuttyman,
      I noticed you use denatured alcohol to pre clean the part. Is that better than Acetone and Purple power, which is a cleaner/degreaser? I've tried Acetone, then purple power and then acetone again and I'm still getting some carters on the final PC.
      Ben
