Powdercoating Aluminum
  • Powdercoating Aluminum
    Do you need to zinc chromate aluminum before powder-coating it?
    Thanks,
    George
    No, it's not needed but it does help promote adhesion.
      Thanks Dale!
        What do you think of a light sand blasting instead? Would that be as an effective foundation as the zinc.
        TIA
        Karl
          Sandblasting does rough the surface and yes it helps but for different reasons.1- by roughing the surface you increase the surface area slightly.
          2 you create places for the powder to physically get in to the nooks and basically hold on.
          3- it physically cleans the surface of paint,dirt and oils that prevent adhesion.
          Zinc is a conversion coating that attaches to the aluminum and then the powder bonds to the zinc. <- this is over simplified but you get the idea.
