Sandblasting does rough the surface and yes it helps but for different reasons.1- by roughing the surface you increase the surface area slightly.
2 you create places for the powder to physically get in to the nooks and basically hold on.
3- it physically cleans the surface of paint,dirt and oils that prevent adhesion.
Zinc is a conversion coating that attaches to the aluminum and then the powder bonds to the zinc. <- this is over simplified but you get the idea.
Powdercoating Aluminum
Originally posted by DALENo, it's not needed but it does help promote adhesion.
TIA
Karl
Do you need to zinc chromate aluminum before powder-coating it?
GeorgeTags: None
