Looking for hi-temp filler
  • Looking for hi-temp filler
    I saw some high temp body filler (advertised 450 degrees) for powder coating on eBay. I would like to avoid buying it on eBay. Is there something like this commonly available? I have a beer keg that has been badly beaten, and would like to smooth it out and powder coat it chrome. If you have a brand name, that would help too. I'm in the suburban Chicago area. Thanks!
    Hemi-T
    Lab-Metal is manufactured by Alvin Products http://www.alvinproducts.com
    I had a discussion with the technical folks at Bondo/Dynatrol about this yesterday. There seems to be a market for this type product. James said their Dynatron? Metal-Fill will not work for traditional powder coatings. It is a polyester bound aluminum filled materil, good for temperatures up to around 250F
    We have also looked at JB Weld.
    -Scott
    J. Scott Moncrief
    Manager-Engineering, R&D
    Livingstone Coating Corporation
      I checked out their web site, and called a local supplier, and they do indeed have it available. The price is right too. $37 for a 24 oz can of high temp (up to 1000 degrees!) filler. That should more than take care of my needs. Thanks for the tip!
      Hemi-T
        See Pyro Putty - http://www.caswellplating.com/aids/pyro.htm $29.95
          How many ounces to a can? Will it bond well to stainless steel? Thanks!
          Hemi-T
            Pyro-Putty
            We have tried numerous times with stove and muffler putties and cements, with less than desireable results. What are your experiences with this material?
            -Scott
            J. Scott Moncrief
              Lab Metal....
              I've found Lab Metal in my local welding-supply store....
              Walt
