air tight oven vs vented oven
  • air tight oven vs vented oven
    another thing i am confused about. I read about how you want a nice air tight oven with a door seal...... but then i read you should vent your oven... how does this work.
    What is the purpose of venting besides letting fumes out? does the air expand that much during heat up? How does one vent an oven without loosing all the heat like a chimney?
    Re: air tight oven vs vented oven
    Hello purpony
    Yes you need the oven vented. Just install a 1 to 2 inch pipe through the top with a couple of 90*s to form a upside down U. That lets the expanding air out.
    bikerdad46
      Make sure you only use around a 1/2 dia. pipe, 1 or 2 inches.
