Door seals
  • Door seals
    Hi Guys (again...)
    I was using 'Woodburner Stove Glass Seal Tape 25mm Glass Fibre Gasket Tape Self Adhesive' for my door seals from fleabay, which was fine first time but it's now coming off.... What do you guys use on your oven, but I'm restricted to a 4mm or 5mm thickness as the door is fitted?
    Cheers
    Ian
    Macmaster.com has seals and might have just what you need if you have not found one yet? This number is for the oven door but at least it will get you into the seals so you can look at what they have 8815K26
    Powder Coating It @ Dad's Garage
