Wiring PID to Inkbird IDT-ER2H Timer Help.
  • Wiring PID to Inkbird IDT-ER2H Timer Help.
    Hello all! I had just started wiring my control box. The PID controller wiring is pretty straight forward itself ( https://www.amazon.com/Universal-Tem.../dp/B018BVVHK6 ). I am just a bit confused about wiring in the timer. This is the timer i have ( https://www.amazon.com/Inkbird-Digit.../dp/B008KV65MS ).
    When this timer is wired how exactly does it function? Can it be set to activate when say the oven reaches temperature and the timer starts?
    *edit* I am using 220v 40amp 3 wire with ground. Also is a fan and single light if it matters.
    After more and more digging I came across this post. https://forum.caswellplating.com/for...-oven-controls
    The b2e timer is set up exactly the same ... with the exact same instruction manual as the inkbird IDT-E2RH timer.
    Hope this helps anyone out who had the same issue I did.
