Propane Oven Issue
  • Propane Oven Issue
    I am in the process of building a propane fired oven. Auber 2342 pid, Dyna Glo 300k Forced air heater. Oven will power on, and fire heater, but the heater will only run for a few minutes then flame shuts off. Any suggestions?
    Thanks
    Flow issue? The Smart controller on the heater will shut it down if the flow is too low (Gets too hot too quick or some other measuring concept)... This would be my first idea to approach. Maybe open up the oven and see what it does with the door open for a test.
    sigpic
    See photos of my work on Facebook "Scottrods Powder Coating"
    EMAIL scottrodspc@gmail.com
      Thanks. It seems it was a issue with high limit switch. Now I just need to figure out settings for temp control.
