oven build element help
  • oven build element help
    i am building a 6x6x8 oven 6" insulation. is four 3000k elements good enough to heat up for powder coating?
    Barely... In reality , I think another 2 elements would be better, but I have seen several ovens with that configuration working daily. Insulation is great at 6" but your recovery time to temp is going to be horrible once you open the door to load... getting back up to temp is very slow when under powered. Could also raise your element size to 3300 or more per element ( 6 of them) to help as well. I'd probably stop at 4' x 4' x 6' with the 12k of heat...
    EMAIL scottrodspc@gmail.com
