Torpedo heater conversion
  • Torpedo heater conversion
    I am looking to build an oven that uses a torpedo style heater. I have no knowledge whatsoever of electronics and would trust a monkey with a gun before I trust myself to wire a pid. Would it be possible to run the torpedo heater without a pid and if it is possible would it be smart?
    Hi....Toss the lamp fuel burner on the iron heap and purchase another propane terminated warmer. About the solitary similitudes are the two of them produce heat from fire and use power. Nothing else is something similar.
    pcb turnkey
