Will this SS Warmer make a good oven?
  • Will this SS Warmer make a good oven?
    Hello All,
    First-time poster. I am looking to build a powder coat oven out of this stainless steel warmer. Interior dimensions 4'4" x 2' x 2'5". My concern is how hot the exterior metal is going to get. This has 2 inches of fiberglass on the walls and only 5/8" on the door. Door is wrapped both front and back in SS. It also seems like they used a fiberglass ceiling tile kind of material for the door (non expert opinion). The white coating does not take a blow torch well. Does not support a flame but does charr. Do you think I can make this work for my hobby shop or do I need to come up with a different plan?
    Click image for larger version
ID:	145049 Click image for larger version
      I'm not sure anyone could give you a definite answer. One option would be to try it as is, then if the exterior gets too hot, stud it out and add insulation keeping the inner shell intact.
