Costs are mounting :)
  • Costs are mounting :)
    OK I'm still in the collecting stage of this build. Blower arrived, it was on special on ebay so I thought I may as well pull the pin now. Also I just ordered Stud and track and in the last moment I have jumped from 92mm to 146mm stud. So that will be about a 6 inch insulation, I'm using a decent blower and 9k watts .... how many cubic feet will I be OK with? sheets come in 8x4 ft so I guess I will try a 2.4H x 1.2W m (8hx 4wft) exterior i.e 2.1h x 90cm ID
    will that be ok considering the thickness of my insulation?
    Re: Costs are mounting
    If I'm calculating correctly based on your given size 9k watts should be ok. It may not heat up rapidly but should get to temp. Converting to inches I get approximately a 36X90 id oven?
      OK in that case I'll cut the height down to 72 inch id
      Cheers
