I have a old BBQ can I cook the powder coating in the BBQ? lets say I put it on a metal tray so no flames fire upward onto the part.
Cooking part in the BBQ?
This is probably the first time i have been asked this.I like new approaches. Ok simple answer-- sure why not. Ok long answer-- if you can contain the flames away from the part and keep the temp consistant it could be done, however I will warn you that the results won't be perfect due to the smoke and ash passing the part will cause defects or blemishes.
how dose the box heater work out ... good results? i got a small toaster oven i been using just for little parts .. but i am going start sending my bigger parts out . to trg for powder coating ...i am just learning powder coating .. and it is not like polishing ...
