oven plans
  • oven plans
    Does anyone have the plans to build a good sized oven to do motorcycle frames 'Sportbikes'. List of parts needed? I cant find anything on the net about it, Maybe one of you guys or girls.. can direct me in the right path. I'd buy an oven, But money is too tight for $5000. lol
    Thanks
    Archer
    I Plead the Fifth!
    check out the pictures in the powder section, sennas built an awesome oven and there are a few pics of the stages he did it in..basically an oven is just a box within a boxwith insulation in between, theres more to it than that of course, i'm hoping some one will post a detailed schematic of howto
    wire the elements... i'm sure someone out there will groan over this but moneys tight here also and i'm basically a scrounger so I built my frame out of old bed frame rails ...
    Pro-Tech Powder Coating
    93976 Ocean Way
    541-247-8168
    [email protected]
    Gold Beach,Oregon
      I can build a frame. its the wiring I cant figure out. I want to build a box big enough to do motorcycle frames, chopper, HD and sportbikes. be able to regulate the heat. Im lost. lol i have been using IR propane heat, its worked so far, I just found out i wasnt totally curing the parts, because it was chipping really easy... so I guess thats a sign of not curing parts fully. i need more practice.. lol and I need to build a bigger sandblasting box. lol my little one hardly holds a valve cover, and bigger parts I need to do and an outside blaster just hurts when ya hit your arm! lol plus Im tired of getting dirty!
      I Plead the Fifth!
        when dale e-mails me the schematic for the two oven element ill e-mail it to you..
        93976 Ocean Way
        541-247-8168
        [email protected]
        Gold Beach,Oregon
